any one know if 91 birds came with anything other then the 85mph speedo and no tach? if so, would one fit in easily or would it take alot of re wireing? I picked up a cluster for a 93 but it looks as if it will need a lot of wireing to make it work. ?????????
I would need to see it. Is it the one with 2 big gauges and it has 2 small ones in between. 1 each on the outside of the big gauges.
He is refering to the base cluster. 85mph spedo, no tach, no voltage.
You cold get the sport cluster for 91-93 cougar, T-bird and drop it in.
thanx
thanx- a 93 will hook up w/o major hassle?
