shaken, not stirred
I found tons of info on "what" gear to get. But the question I have is this, I am going from 3.27 to 3.73. I have the correct speedo gear. Will I have any problems with the tranny shifting? Will it still shift correctly? I am eventually going to get an SCT tuner but I dont have the cash for it right now. I am mainly concerned about how my car will react with the new gears and speedo gear. Thanks
C.Hill
shaken, not stirred
Well I dont have a Jmod yet. I was told that it may be boggy just driving normal? ANyone have any experiience going from 3.27 to 3.73 with only changing speedo gear and no computer work?
C.Hill
Fry Rice Specialist
it will drive the same other than the speed limitier will hit early on like 80 something mph. with a tune that disable the speed limiter then you're all set.
shaken, not stirred
I knew that it would hit the limit due to the lower gearing, I was just hoping it wouldn't affect the shifting too bad. I will get a tuner eventually as i had stated. Just hoping it will be ok untill then.
C.Hill
