hey everyone, i just finished installing my new rebuilt pumpkin with 3.73s and was wondering if i needed a speedo gear change since i went from 3.27 to 3.73gears.. is it necessary to change the speedo gear or is 3.73s a small enough jump to where the computer will compensate?And if so what speedo gear do i need? oh and by the way, any other info for break in period since everything is new would be greatly appreciated...
just take it easy on the gears for about 500 miles or so....
you need the purple speedo gear. it needs to be swapped out or the speedo will be off.
thanks for the quick replies...does anyone know how much gear lube i have to put it in? I think i"ve read somewhere that 2bottles should be good or atleast till it overflows out of the overfil hole? is that correct? and how much friction modifier is needed if i use lucas full synthetic for lsd applications?
Go to the ford dealer and pick up two bottle of their lube and a bottle of Ford friction modifier. While you are there pick up a purple speedo gear (21 tooth); they only run about $5 last I checked.
-Miller
