1 - 1 of 1 Posts
When I first start driving in the morning, or after the car has sat for awhile, the speedo will work fine. But after roughly 6 minutes or so, every time, it will start to give out, dropping to zero, then back up to whatever speed I am at, then back to zero, till finally it goes to zero then stops functioning altogether. I am not sure if it is the signal coming from the speed sender/sensor on the tranny (5speed) or the speedo itself. My cruise control will continue to function, if that matters at all. Also, all of m gauges seem to read low, oil pressure, temp, and the fuel runs out just above the red line above 'E'. Can anyone offer any advice here?
Thanks
Phil Stocker
1 - 1 of 1 Posts
