Hittin' Switches
so i know the speedometer is soposed to be off, How do you fix the speedometer?
I would like it to show the accurate speed, also, does anyone know if you are running 245/35/20 tires, and your speedometer reads 60, how fast are you really going?
Matt Musto
Use the Tire size cacluclator HERE to answer your question.
I think you can correct the speed for different size tires with the SCT-X Calibrator II.
only on vehicles with a magnetic pickup VSS.....ours is gear driven.
CEO, WT Club
Ed is right, your size is close enough. You shouldnt be having problems.
-Joel
