My speedometer was on the fritz by not reading anything below 30mph. It did this for a couple months before eventually dying completely. The odometer doesn't work either. I replaced the odometer gears a couple years ago so I am looking at the VSS. Is this the issue? I cant pull codes cause alll I get is an error message,
Discussion Starter #2
VSS was switched with another with no change. I took apart the speedometer and everything looked kosher. Im broke as a joke so any recommendations will have to be done cheaply
Maybe the speedo unit died. Check the wiring for the VSS for cracking or bare wire.
Can you datalog a 95?
Vss is one of the things I can see in my 96-97 cars.
The 4.6 yes, the 3.8 no.
(4.6 is OBDII, 3.8 isn't.)
Put on a new VSS and took apart the cluster again and got it working.
