OK, I have had a speedcal from Dallas mustang for several years, and had no problems with it. I swapped my 4.10's (open diff) with 3.73's (track lok). This was performed by my local ford dealership. Now, my speedo reads approx 10mph too fast @ 70mph. I have contacted Dallas mustang, and they gave me a new dip switch setup, and its still reading off. Now, I'm wondering if there's something awry in the diff, or possibly a sensor. Any input would be appreciated. ('96 T-bird, 4.6L)
You really don't need the speedcal for 3.73s. The purple 21 tooth speedo gear works fine. I'd put a new speedo gear in and take the speedcal out of the equation and see where that takes you.
That might get me pretty close, but I'm also running 255/45r17's, so it would still be off a bit. (not much, I know, but just enough to piss me off.)
I'm running the same size tires; my speed is off by about 2%. If I'm going 70 according to the speedo, I'm actually going roughly 68.
well, that's not too bad off. guess I'll give it a shot and see what happens. Thanks.
Easy fix, check the Electronics area of the forum and look at my writeup on the Speedcal. For your initial PPM use 8000 to eliminate the 2% of error.
Ripped out the speedcal, installed purple speedo gear, problem solved. Thanks guys!
want to sell speedcal cheap? pm me.
