How inportant is the sprin isolators/pads. You know the things that go inbatween the springs and the frame. I am rebuilding the suspension in my bird. and when i torit it apart i found that there was no pads exsept for the rear driverside uper pad. I called ford and they said they ar no longer avalable (wow what a serprise) i called shucks, They dont have them. Any one know if i should take the time and go to a junk yard? or i can order the poly ones from summit. but i need to mesure them. thanks
dan
95 T-bird LX 4.6
84 T-bird Elan 5.0
63 Lincoln Continental 430 4bbl 7.1L
I purchased spring isolators from Dan Newman at 5-Star Ford.
In my opinion, you should have them.
I do not know if anyone has actually NOT used them.
Discussion Starter · #3 ·
84 bird need new isolaters
the isolaters on my 84 needs replacing. sorry i forgot to say that. Acording to what i have heard the fox stangs isolaters are the same. But not acording to my local ford store. they are jackasses any way. any one know. i know ES has the poly ones.
dan
95 T-bird LX 4.6
84 T-bird Elan 5.0
