1 - 2 of 2 Posts
hey guys, im about to purchase the eibach pro-kit spring set, and before i install is there anything else ima need to buy? what are spring insulators? spring seats? lol ima kinda confused.
You might want to consider new upper shock/strut mounts for the front, as well as new spring insulators/seats for the rear. Now would also be a great time to consider doing shocks, tie rod ends, strut rod bushings, front lower control arms, front upper control arms, sway bar endlinks front and rear. Many choose to do it all at once. Also the springs must be removed and installed from the front shock/strut using a wall mounted strut compressor, it is EXTREMELY dangerous removing them any other way. By ordering new shocks/struts along with front upper mounts it allows you to remove the assembly without having any down time.
1 - 2 of 2 Posts
