this is kind of a weird issue that popped up about a week ago thats got me scratching my head. when the car is first started is makes a weird puttering noise. you rev it up a little bit and it will stop. as you are driving it and you go over 3lbs of boost the puttering gets relly bad and nearly dies. i checked the vacume lines, just glancing over them and everything appeared ok. has anyone had this problem before??
91SC
Kinda sounds like a MAF to me, or a boost leak (intake gasket). Although i'm not sure if these engines even have a MAF, lol.
they do have mafs
check for leaks around the intercooler piping.
the mafs could be dirty. but most likley its a sparkplug or plugwire issue
generally the dis needs replacing when the tach starts to goof off.
you can have it tested, even buy heatsink compund to extend its life, but i am telling you get new wires and plugs thats is the biggest cause of stumbling in boost. get double plats and dont do them for another 3 years.
check the maf, and make sure that your getting fuel. clean the injectors and make sure your getting over 40psi of fuel in boost.
not trying to jack the thread but you talking about the rpm tach goofing off???? becasue mine does it all the time bounceing up and down LOL
