Im looking to replace the bushings on a Thunderbird SC subframe that I bought to put under my 1989 Base. I was looking on RockAuto at bushings and there are like four different size bushings to choose from, how do I find out which ones I need?
Measure the diameter of the sway bar.
-Rob
supercoupeperformance.com would have the size you need but there are a couple sizes of sway bars for the SC's. Was it a gen1 SC you took this from, 89-90s are a bit bigger than 91+
I dont know, see. I got it from a dismantler but they pulled it. My receipt says (1989-1992) but I really dont know...
The bushings I have right now look decent but I am replacing everything else so I may as well replace mine for the hell of it.
If you dont have a micrometer to measure it the easiest way is to take an adjustable wrench and fit it on the bar, then measure it with a tape measurer.
Bar
Remember that SC & non SC have different bar sizes threw 92.
even the V-8 cars had a different size.
:cool:
:cool:
I know it is from an SC, but I do not know the year.
