I'm curious to know if you run a staggered tire setup with a bigger rear bar, will a car handle like a balanced setup?
We know that a square setup on tires and even bars will keep a car balanced for handling. We know that having staggered tires and even bars, the car will tend to understeer. We know that having square tires and larger rear bar, the car will tend to oversteer. One of the most common sized staggered width tire combo I see are 255 (F) / 275 (R). So it makes me think about having a staggered setup with larger sway bar and how that will impact handling characteristics and is where my questions lay:
Will having a staggered tire setup with larger rear bar compensate for the smaller front tires and give the "feeling" of a "balanced" setup?
So for example, if one were to run a 255 (F) / 275 (R) and the ADDCO 1-1/4" rear sway bar, would the car feel "balanced"? If it wouldn't, would the car oversteer or would it understeer?
To here who have ran such a setup before, what were your experiences? What was your car built for?
I know that an ideal setup is to run square tires and even sized bars. The reason for the question is because there seems to be an issue with production of the ADDCO front sway bar and who knows if ADDCO will continue to support it.
