MaleWhore
the 3.8 is at it again
try to start it today, and it wouldnt.
it has a new battery, it has a new starter. i double checked both of those and they are perfect. all it does is a clicking noise. i had my friend sit by the starter and it would even do anything, so im thinking its not getting power. i bypassed the selenoid and it just makes a click(selenoid itself). im thinking there is something after the selenoid itself that is screwed up. any help? how can i check whats wrong.
What kind of shape are your battery cables and terminals in?
MaleWhore
cleaned them up, and they look pretty solid...
MaleWhore
i just tried it tonight out of no where it just cranked up...didnt do anything to it...it just started...weird....
MaleWhore
which wire is the ground? the thicker one?
The starter body is the ground. Check the ground connection at the negative battery cable, and any engine grounds. Check battery voltage when it's acting up, too. You may have gotten a bad starter or battery. If the starter was installed with a distcharged battery, it could have fried the new starter. (low volt=high current=hot starter). But I'm with Jimmy, if all this was going on before, I'll bet its a bad ground.
