Every once in a while, the car will not start right up. After about 30 secs- 1 min. of turning the key back and forth, it will turn over. At first I thought it was my worn key, but have replaced that. WHen I turn the key, it doesn't crank or anything. All i can hear is a click then silence.
I thought that click was the solenoid? Is there any other way to check the solnoid?
It has done this about 5 times in the last 2 months (daily driver).
Thanks for the insight.
one other thing...how do you jump the starter, just in case it won't work before I get it fixed and I don't get stuck somewhere. I have heard using a screw driver to open the circuit, but where exactly are the points (closed circuit) to do this in the 4.6 bird? Thanks
Related Threads
TCCoA Forums
1.5M posts
26.9K members
Since 2002
