Here's the deal... several months ago I parked my 90 SC due to several problems I couldn't fix at the time, so it has been sitting for awhile.
Multi-problems:
Let me start from the beginning.... it all began with a problem starting which I first thought was the battery and replaced it. But it continued to be a problem. It was like it would only hit on every sixth try or so... several concluded that it must be either the cam and/or crank sensors. Then, 70 miles outside of town it started running rough and bogged down, diminished power. We ran a code which said was the bypass valve on the charger and also found a crack in the hose connecting the CAI tube. We duck taped that and disconnected the belt on the charger to get her home. At the time I couldn't fix, and parked it, but it has been awhile since I've tried starting again.
So she needed a jump and now has a new problem... I cranked and cranked, she'll turn over but not start. Almost seemed like the accelerator wasn't connected... every other time it would act like it wanted to start but couldn't rev it up to take hold. Then just by accident I held the ignition switch forward while starting and she started right up... let go and she'd die. Had to hold it just right, any further forward and the starter would re-engadge, any less and she'd die. Held in this position she seemed to idle fine and would accept acceleration. This one has me baffled. Can't hold the ignition, steer and shift gears to get her to the shop. Perhaps the battery hasn't charged enough or the altenator has gone bad? I know the battery does some weird things when it has lost charge.
Any thoughts?
Multi-problems:
Any thoughts?
