1 - 20 of 24 Posts
Crank and waterpump pulley
90 shipped you cover the fees
do these retain the stock size belt or do you need a different length?
These run stock belt because we removed and put stock parts on and same belt
Robert
Smaller harmonic balancer replacement type or piggyback?
There steedas no piggyback junk I'd throw them away lol also there my buddys and he needs money
Robert
I have the same pulleys on my car. They are great! I paid a bit more for them, so this is a good deal.
It uses the stock belt, the pulleys are just different sizes.
What kind of a gain does Steeda claim on these? Did you feel a difference?
Do you have a part# or pic? Why only a 2 piece set? I thought they were a 3 pcs set?
If you still have not sold these on Friday 7/30 I will take them.
How do you want me to pay?
Jerry
paypal or money order around 10 hp because the alt pullys slos the alt down even more
Do you have the part# so I can have it for my records?
That third pulley isn't required. The size is exactly the same as stock. I don't know why it was a part of the set to begin with.
Here is a part number and description, http://www.steeda.com/products/steeda_4.6L_underdrive_pulleys.php
As far as gains, I am not sure since I did my gears at the same time. It won't be really big, but it will give you a little. You might want to bump up your idle speed with your tune. I believe you can do that from the device itself.
Thanks Comet.
I paid $150 for mine, so this is a good deal. It would be a nice addition to your car (which is really nice, BTW).
Thanks again for the info Comet and thanks I need a paint job but want all the mechanical stuff done first paint is last after SC next year.
When I get into the 11's with the AED then it is time for paint and I drive around with a BIG smile on my face.
Jerry
Another uhh...."feature" of the steeda pullies is that the water pump pully is larger due to the crank/balancer pully being smaller, so it covers up the right side bolt holding the alternator on just enough so that the water pump pully must be removed in order to remove the alternator...
When I get into the 11's with the SC then it is time for paint and I drive around with a BIG smile on my face.
Jeryr
Paint is always an issue. Mine has seen better days, but its silver so it hides it pretty good. I found some more things broken this year so my painting will have to wait.
No prob, thanks
I am a pro at pulling the front of my motor down did it like 3 times when I did my PI Cams. :)
Yeah, and we should have pulled the engine when we did those valve seals.
Really was it that hard??
You just have to pull the valve covers right?
The way we were doing it, we had the engine hooked to the air compressor to keep the valves in place. Then we had to remove the old seal and spring and install the new ones. Some were very hard to get to with the engine in the car.
1 - 20 of 24 Posts
