1 - 11 of 11 Posts
I dont know if this is normal for birds, but my '94 T-Bird w/ 189,000 miles, has a very stiff gas pedal. Is there something I can do to change this, 'cuz I like a very sensitive pedal. Also my motor does this bogging thing at throttle tip-in. I'll be cruzing, then tip-in to accelerate a little and it will sound like its trying to, but just bogs. I then have to step on it kind of alot to accelerate again.
Could this have something to do with my torque convertor clutch? I know my convertor is in bad shape, cuz it has the carachteristic "shudder" these things get.
If no then, is it a fuel issue?
for throttle responce clean the throttle body (dispite its warning) while open with a paper towel and some b-12 chem tool, oil the cable and linkage if nessasary, as far as the bogging clean your maf, and as far as the shuddering convert to merc 5 or if your fluid is new (less than 15,000mi) than pour in some heartland T3 additive....from what I've read its supposed to bring it up to merc 5 spec.
That's what we use at Jiffylube when doing transmission fluid exchanges... Dex/Merc III + Heartland T3 = Merc V
-Ghost
uh huh, sounds like throttle cable is rusting inside it's housing. that or it's got a kink in it. i'd say flush tranny with merc-V. fresh fluid is never a bad thing in these trannies, or ANY automatic tranny. they tend to get neglected.
also, i think i remember reading that the 4.6s can have flat spots in acceleration.
-Ghost
yea we use it at Terrible Herbst Lube shop too
thanks guys, I'll bet the throttle cable is rusting or kinked. Unfortunately I modified my stock MAF, so I think that something to do with the bogging. As far as shudder goes, I know my trans is F***ed, merc 5 wont do crap at this point but blow my trans. But I have a new one waiting to go in. I'am suprised at what a stock high milage 4R70W can handle though. I down shift into second at 45 mph everyonce in a while, and it takes it like a champ. Also I've had the stock convertor spinning at 5800 RPM before ( damn Mustangs are too fast ), and it seems to be OK. I heard that past about 5200 RPM it starts to balloon.
Anyway, thanks again for the responses.
did you open ur maf up, as in cut the bracing from the inside of it. i tired that it dont work. to much airflow for the computer. need a tune for it if that what you did.
yep, thats what did. You say I need a tune? What kind of tune?
02 Explorer Pioneer
no tune is going to overcome that mod. just pick up a good used one and replace it
Yeah.
You NEED to replace that MAF with an unmolested, clean one.
The MAF must be clean, and to stock specs.
By tune, he means a tune for your computer. Speed shops create "tunes" or files for your computer and change the settings for performance.
The MAF helps determine A/F ratio, and you can see how tricking it without informing the computer what you did, will be problematic.
1 - 11 of 11 Posts
