1 - 12 of 12 Posts
1994 XR7 , 46 most every option. 66.000 miles. rustfree, from washington state.
had heard years ago that ford used organic rake material for there pads in the early
90s. so what is the best material or pads to use in an all stock 94 cougar with 4 wheel discs and abs. want something that doesnt leave black on the wheel and wont ruin stock rotors.
do they even make an organic pad anymore?
I would either get the Ford ones, or I've had good luck with Autozone rotors & "gold" pads. Pretty sure they were semi-metallic. Order online and pick up in the store, save big $$.
Always get new rotors, and do a proper break-in right away, which is some really aggressive braking slowing from 50-20 real quick 10 times in a row, followed by cooling for an hour or so, then repeat. Really made a difference on the Crown Vic.
I'm a firm believer that black soot on the wheels goes hand in hand with good braking. Can't have everything. I had some unknown pads on my Toyota when I got it - they didn't put any dust on the wheels - but brake response and stopping power was crap.
Al
I just put a set of AutoZone Golds on my Honda a couple days ago. I'm not pleased with them compared to the PowerStop pads I had.
The AutoZone Gold pads have good initial bite, but they do have pretty aggressive brake fade.
Don't the Powerstops need the Powerstop rotors also? They are ceramic, correct?
Al
I'm not sure?
The only reason why I replaced the pads was because my driver front pad had worn out unevenly. Apparently I applied too much brake grease to the slide pins and they weren't going all the way down / in. Otherwise, my Powerstop pads would have had at least another 25k miles before they would have been rubbing on the indicator pin. I'm not sure if it matters any, but the AutoZone Gold pads I put on, I had them in storage for a few years before using them. I even contemplated throwing them away, but now I'm glad I didn't.
I think when the rear pads go, I'll replace all 4 pads and rotors at once with another set of Powerstop units.
I agree that the better the pads stopping power, the more dust they create. These Hawk pads I put on drastically improved the braking but my front wheels are black after like 50 miles. They also squeal, but I can stop now!
Discussion Starter · #7 ·
you talked me into it . 4 coated powerstop rotors .
  • Like
Reactions: CDsDontBurn
You get them on or are they still on order?
Be sure to get them bedded in after putting them on.
Definitely do the bed in process. When I put my Hawks on I did the bed-in procedure off their website. About half way through I noticed the brakes were grabbing a lot harder. So it definitely works.
Discussion Starter · #11 ·
put front rotors and ceramic pads on only. the backs are hardly worn and nice rotors. cancelled the rear rotors and kept the pads. sure are shedding the black stuff up front. thought it wasnt sposed to do that.got about 150 miles on them.
other cars i put ceramics on didnt do that. think they were delcos.
I'm curious about how the various brake pads mentioned above compare to KVR (carbon-fiber semi-metallic) pads that came with the PBR brake upgrade kit and to the EBC (redstuff, yellowstuff, etc.) pads, if anyone can provide any comparisons. I will need to do a brake job at some point, though I hope I can just do that when I do the hub swap at the same time, and more affordable brake pads are always welcome.
1 - 12 of 12 Posts
