what is the stock exhaust manifold outlet diameter for a '95 4.6?
Chapter Director Coordinator
reason for question? just curious... because it doesn't really matter if you want to enlarge it unless you open up the inside as well... i can get a measurement for you in a little bit if no one responds before me
I just don't want to do a 2.5" custom exhaust if the outlet diameter is only 2.25". I'd have all that space for flow for nothing.
I want to know this too actually. If someone could get the runner dia as well that would be awesome. Thanks!
i have a set of ported braincoated manifolds and a set of stockers
if i get the ok from tbirdbrain, i'll post the numbers. there isn't much different in the outlet or the inlets...but the meat in the middle... i have no way of measuring runner diameter inside the manifold...but i know how much was taken out
for the record.. RobertP has brain coated super ported manifolds and 2.25" compression bent exhaust...and runs 11s
Oh, I'm not doubting the potential of the stock manifolds. In fact, I talked a guy out of spending $$$ on the jbas in favor of the stock; citing the guys running 11s with ported stockers. I'm trying to setup a group purchase for true dual exhaust for the local club, I just need to know what size would be the best to go with.
