I was changing the fluid and replaceing the 1-2 accumulator with the updated version. Just before I reinstalled the pan an unexpected storm came up with strong winds and rain.
While I was reinstalling the pan water was running down from above me, past the pan as I was installing it. There might be a small amount of water that made it inside.
Should I take the time to remove the pan again and wipe out any water before adding the fluid? Should I just let it sit for awhile before adding the fluid and hope it will evaporate ?
Wishing I had a garage.
You need to get that water out of there before you run it.
Water will kill the clutches quick like!
So drop that pan, you know you love Mercon V showers as much as me :D
How much water do you think would cause a probem?
There is probably only a few drops inside.
If it was my car, and there was just the possibility of water, I would dump the pan.
Thanks for the advice.
Not the solution I was hopeing for, but better safe than sorry.
Well I dropped the pan and wiped it out, didn't see any water. Nothing like having to do things twice:redmad: , but I feel better knowing it was clean.
