Okay, I am probably sure that some one has posted this problem before but unfortunately I have failed to find the thread. I am driving a 97 Tbird, with no mods to date, the problem is that while driving over and intersection with a little bit of a hump (nothing to horrible but just an average intersection), off the line, I am at WOT, As soon as I get to about 4500 rpm, the car shifts to 2. Sounds normal Right, but it doesn't take in 2, it is almost as if i put the car in neutral, or like it just slipped gears? i have just recently had my fluid changed to mercon V, and no problems for about 500 miles, and now this. Any help would be appreciated, I am wondering if my TC isn't going bad.
double-check your tranny fluid level....after running the car for a while shortly after a drain/refill, it will sometimes go low and cause it to slip
mine use to do the same exact thing, it was completly normal till I took it to WOT, well changed the fluid and the filter and all good. How many miles on your tranny. Since you did a fluid change recently have you checked if you are not leaking anywhere, maybe you filter fell in the pan.
3rd Gear Chirper
Hmm, sounds like maybe your filter fell down into the pan. I always safety wire mine onto the valve body. When I failed my old trans I pulled the pan and found the filter sitting there in the bottom of the pan, so now I just use safety wire.
thanks for the info, i have only about 750 miles on it sinc i changed out the fluid, i will check out the filter and see if it is in the pan. Oh and as for mileage on the tranny, i am sitting at 120000, with to my knowledge, only one fluid change (the one that i did).
