one in a million
hey guys.
Had to pull and clean iac, and now can't get one of the bolts to tighten up.
is there a oversized bolt i can use or does it need to be retreaded?
somehow I crossed-threaded it.. :facepalm:
only thing holding it right now is one bolt and a lot of teflon tape on the other bolt.
any help/advice appreciated..
Thanks...
If there's enough thickness to re-thread it, I'd go that route.
Personally, I'd grab the first bolt laying around that is just a bit bigger, and that would fit, then tap the hole to fit that.
Going from metric to english often gives you a close option; metric is usually just a bit smaller than the similar-sized english bolt. :)
Use care so you don't go somewhere you aren't supposed to go; the proper length/depth is important. :) Get "bottoming" taps, that will tap to the bottom of a blind hole. There is a difference in taps... :D
If it opens into a passage, even a crack, use red locktite; it will go on fairly thick. Coat the whole bolt; it will seal.
one in a million
fixed.
tried out a longer bolt and found I had some threads left.
worked out well, snugged it just enough so it won't come lose.
bolt size is M6-1 X 35 Lawson item# 1332297
thanks.
