1 - 10 of 10 Posts
Fry Rice Specialist
fighting with it for 2 hours just now, can't pull it out. how can i pull it out? it won't bulge. will continue tommorrow.
anyone have any suggestion? i've try pry at the front and back but those piece is on there good. already half a can of pb blaster gone through it. i think the 2 metal sleeve are fuse together, any idea how to unfuse it?
thanks.
Over on MN12Performance.com, under his front end rebuild, he mentions that you have to cut a lip off to get the ferrel out. This could be your problem.
Here's a link. About 2/3 down the page for strut rod instructions.
Rob
Fry Rice Specialist
thanks for the help.
now the passenger side front strut rod nut strip at the end, i'm cutting the end of the strut arm out with the tread on it.it has about 3/4" thread left on it. can i reuse the stut rod arm still? it still has suffient thread on it.
thanks.
Fry Rice Specialist
this job is start to pissed me off. got the driver side done and now this passenger side are throwing me off. both side i'm having hard time getting the nut from the strut rod to lower control arm out. driver side took me few hours and now this passenger side i can't get it to bulge. i'll be taking the arm to the shop tommorrow to let them take it out for me.
GGGRRRRRRHHHHH!!!!!!
Rob
Was this the problem or something else? I need to know because I'm about to start this myself.
Rob
Fry Rice Specialist
sort out those problem. now in the middle of bolting everything up. i got a new strut rod from junk yard because the passenger side strut rod nut at the lca just wouldn't bulge. got a new nut with washer to go with it. it's not a hard job. i use 2 jaw puller to pull out the bushing. those nuts are driving me crazy. i'm a small guy and i don't have enough muscle to break those nuts off even with big breakers bar. most of the problem is rusted out threads.
thanks.
What did you end up doing for this? Did you have to cut the ferral like in the link I gave you or something else?
Rob
Fry Rice Specialist
i didn't cut out the ferrul. i use a 2 jaw puller for it.
finish the swap 5 minutes ago. go for a test drive and then clunk, jack up the car again and found out the driver side lower control arm bolt to the frame(the one that adjust the alignment) loosen out and the control arm wobling while test driving. tighten it up again and its all fine now. will do alignment tommorrow.
1 - 10 of 10 Posts
