1 - 10 of 10 Posts
STRUT ROD BUSHING can anyone please show me a pic please
sory all i know is that i need them too so ya people show us
Amateur Expert
Here the strut rod bushings are outlined. There are two sets of bushings. One where the strut rod goes through the lower control arm, and the other where it goes through the K-member.
The Band, not the Disease!
A good way to tell if they are bad is, put the car in reverse, get a friend to look at the wheel closely. Slowly go backwards then hit the brakes. If the wheel moves FORWARD while you stop (it will actually "shift" forward...) then the Strut Rod bushing in the LCA is bad. Do the same thing going forward, and see if the wheel shifts backwards. If that's the case then the Bushing going to the K member is bad. I replaced my Strut rod LCA bushings, my wheel would shift. Now I can feel the wheel move when I am rolling forward then brake. Time to do the bushings to the K member.
Fry Rice Specialist
get the Ford OE bushings. Do not get the Moog thermoplastic ones.
why not moog, i just replaced min with moog, i actually just replaced EVERYTHING on my front end with moog. dont tell me ive got to replace them again!!!???? AARRGGHH!!!
do a search on their failures. Most of the pics you will find are from my car. Im on my 4th strut rod bushing since october 2003.
1 - 10 of 10 Posts
