1 - 15 of 15 Posts
Strut Rod Bushings are shot again (2 years). I don't remember what brand these were, but they Suck.
What are the best recommended Brand on these since Ford ones are long gone?
Bruce
I went with the Quick Steer improved design bushings. Quick steer is owned by Federal Mogul, which also owns Moog. These were cheaper than Moog but they feel just as good. I got them off of rock auto. The material used to make the bushings isn't listed but it feels like polyurethane.
Agreed, ford parts only for this location, and the bushings are still available. The part that is no longer available is the strut rod bushing sleeve, however if yours is destroyed, there is a member on here who sells a stainless steel re-usable one, which is pricey, but you will never have issues with it again.
Well now I feel like I screwed up. Has anyone tried the ones I got or is it a general consensus that you should only use ford?
Many people have tried those ones. The polyurethane is not an appropriate material there because it has to flex as the suspension moves up and down, and poly cracks instead of flexing. You need ones made out of rubber, and so far no aftermarket supplier has made rubber ones.
1994 Cougar XR7 DOHC/5-Speed
Thermoplastic. Same thing as poly basically but these seem even more notoriously failure prone.
Any of you thinking long term on this? People have managed to get first gen Mustang(65-73) Polys to work before on these, so it should be possible to use their abundantly available rubber ones..
Should I return these and buy the ford ones, or use them for the time being
Q: Do you have a deal on alignment or will you DIY that yourself? Since changing the frame side strut rod bushings will change caster, unless you have some kind of free lifetime alignment deal, I would just buy the Ford ones.
-g
Is there anything to replace aftermarket wise that helps prolong the life of these bushings? I also too have to change mine and it will only be every mn12 ive owned now.
I just learned yesterday from the others that aftermarket isn't good in this situation, try to get OEM rubber ones. XR7 told me 66 stang ones should work so I ordered a set of those cause they seem to be cheaper are a lot easier to find.
There is a link posted by RaceCougar if you go up with more info on this
1 - 15 of 15 Posts
