tell me about it, there isn’t enough people to get it going. I’m seriously thinking of doing my own cheapy design and getter welded up soon.I've been looking for years, Good luck!
I believe if SCP gets 15 people interested, they'll be made. But $220 + Shipping seems pricey.
sheesh I would of took off like a bullet to go grab it! I’ve read many reviews on here and some guys say it makes a big difference and others say it’s a placebo effect. Only one way to find out! I have the material to try and knock it out, I’ll keep you guys updated on the project, I’d be down to make a couple sets if possible.About a year ago SCP did make a batch. Not sure if they have one lying around or not.
@Noser7mil ,I saw one at the Rialto LKQ a few months back. I thought you grabbed it after I posted it? I would have, but I never had the time to go out there. The car is gone now.
Yea for sure I did mock one up a lil while ago that I think would be able to clear that without the notch.That notch is going to be an issue as it won't provide much rigidity. I understand now why the SCP design comes forward a little bit. It's to clear the IACV vacuum hose.
They are. It’s convenient to lean on though 🙂I see mustangs with strut tower braces and I have one for the rear ready to install. People on Facebook say that the rear strut tower brace is placebo, could be a rather expensive 220 for engine bay bling.
I wonder how it would fit if it bent going backwards towards the firewall?I bought a new piece of metal and gonna try again this weekend. So far it did clear the hood and everything.
What doe you mean backwards towards the firewall? Like instead of going directly in line to the other tower, you go behind the plenum?I wonder how it would fit if it bent going backwards towards the firewall?
Or, what if it kept the shape as the one that is notched (pictured above), but instead of a tub it was a flat "I-beam" type piece? Something similar to this DC Sports bar. Basically, something that would clear the IACV tube and allow for the hood to close, but still have structural integrity needed for the strut bar to be functional.
The best type of STBs tie into the firewall. So he may mean that. Aka 3 point braces. Cause triangles be strong n' shieet.What doe you mean backwards towards the firewall? Like instead of going directly in line to the other tower, you go behind the plenum?
That's not what I meant, but I did already know that. I have an idea (probably someone had the same idea) on how to make this happen. Essentially, weld a "mount plate" behind the firewall with screws pertruding through firewall. That screw plate would be the anchoring point for the triangulated strut bar.The best type of STBs tie into the firewall. So he may mean that. Aka 3 point braces. Cause triangles be strong n' shieet.
Which is why I said....If the towers actually moved anchoring it to the flimsy firewall sheetmetal will just flex it and crack it. You’d need to reenforce the mounting area for it to be effective which it won’t anyway because STBs don’t do anything.
And if they don't do anything, then why do manufacturers put them on as standard on literally everything out there these days? Even the boat of a car my wife has, the '13 Taurus, has a STB. They have to do something for all the manufacturers to be putting these on everything.because STBs don’t do anything
literally everything =/= 2013 Ford Taurus and what’s applicable to one car isn’t automatically applicable to another. GM W bodies used braces diagonally run between the strut towers to the radiator support, does that mean every car that isn’t a W body is a flexi flier? No. Ford doesn’t standard equip a STB on the Mustang, which is ostensibly their sports car, they offer one as a quite clear optional or over the counter dress up accessory, because the car simply doesn’t need one.Which is why I said....
