Hello there,
My name is Brandon, I am having a drivability issue with my 1989 Super Coupe.
Short version, if I unplug my battery for a few hours the car runs great. Idles good, throttle is good, and WOT is good. As I drive the car the engine progressively runs rougher. It starts with a bad idle that shakes the car, to low RPMs around town, to eventually almost feels like a miss at throttle going up hills. This can happen in as little as a 30 minute drive home from work or a few hours. Occasionally, out of no where, the car will run smooth as silk while on a 2 hour drive, but as soon as I turn it off, it gets rough again. No check engine light, however, I do know that the light works as the light will come on if I unplug the MAF sensor or the EGR Feadback, ect.
I want to apologize in advance for the length of this first post, I want to lay all my information out for viewing.
Car in Question:
1989 Ford Thunderbird Super Coupe.
161k miles, Automatic, mostly original.
I bought the Super Coupe two years ago with 155k miles on it, diagnosed a possible head gasket issue, then stored it in a enclosed bin for a year.
When I did pull it out of storage, it ran like crap and did not want to idle. I got rid of all the old gas and replaced it with 93 octane, car ran well after that. Two months later the head gasket gave out, nearly hydro-locking the motor within seconds. Car was at 159k miles.
As of July 2022, the cylinder walls looked good, no signs of scratches or excessive wear. Heads were straight and cleaned. I replaced both head gaskets with Fel-Pro, new ARP Head Studs, new gaskets throughout the motor, new O2 sensors, new Motorcraft spark plugs, new idler pulleys, and did a A/C Delete.
Things I have checked or cleaned since head gasket blew:
I cleaned the IAC, MAF, Fuel Injectors, multiple wire connections under the hood, I also got the coil pack tested which was in spec.
Engine mounts appear to be in good shape.
I daily drove the SC from early July to late September, resulting in over 2k miles, at which point I bought a 96 Cougar as my winter car. I had noticed a exhaust leak was developing around where the exhaust manifolds bolt up to the cats.
Since I have put the engine back together it has not run right. At first it was intermittent, as in as once a week. I would appreciate any thoughts, opinions, feedback, and some insight as to what I should consider replacing or diagnosing next. Thank you for your time.
Car in Question:
