1 - 10 of 10 Posts
Wierd stuff started happening with my SC when driving back to MI from KY. The best way I can describe it is that it was surging while driving at a constant speed, kind of like run,die,run,dierun,die........ in about 1/2 second intervals, if that makes any sense. It would get worse if i accelerated but seemed to get better if I decelerated. I was able to decelerate and then slowly feather in the throtle a few times and then it would go back to normal for a hundred miles or so, then happen again. The first time it happened I thought I was losing my trans from the violent on/off cycling. But when I pulled over it was still surging while idling in park. A couple of times while this was happening, but not always,I lost the tach, then when the engine went back to normal the tach came back.
I replaced the DIS, but no improvement.
The check engine light never came on.
Has anyone ever had this happen?
Help,
Ian
When you lost the tach did you get an upshift light? If so that could be your crank sensor on its way out. Other posibilties include vacume leaks, crank sensor, cam sensor, or computer. Or maybe a combination of things. Of course I could be completly wrong also, but I am sure that there are other people with some ideas too.
The loss of the tach and the intermittent stuttering leads me to think that this is a failing cam sensor. Relatively cheap and easy fix (at least its easier than the crank sensor).
I did not test the alternator because there were no problems with charging or running any accessories. If it was the alternator not providing enough current to run the electonics then my battery would have run down and I would not be able to restart, right?
i dunno, ive heard of and seen on alot of cars when the alternator goes the guages hit the peg and back down just before they die, besides it couldnt hurt to get it tested, they usually do it free at pep boys, advance auto, and others. It could save you a AAA call.
Yeah, I thought about the TPS, but that wouldnt cuase a problem with the tach would it? Do you remember if your tach ever went out when the car was surging?
When I rebuilt my top end after the headgaskets went I forgot to hook my TPS back up and well this sounds exsactly like what I had going on. Only difference being I had a check engline light that would come on. I've also replaced my Cam sensor for the check engine light still came on after the TPS fix and well it was almost like I was running on half power sometimes and then she would be back to normal....Seem like what you're experiencing?
Oh and when my car was at idle it would shake violently, like it was in a spin cycle...it was nuts. Anyways it turned out to be a combination of the two for me.
Another thing came to mind too...when I had this if I kicked it in hard it would surge like you mention. Still ran strong though for I beat a mustang GT when that **** was happening. Also made me think I had a loose plug wire but come to find out it was the Cam Sensor/TPS problem.
Hope I've helped somewhat. Both sensors are a combined $75 bucks at AutoZone if I remember right...I went ahead and replaced both since it was so cheap. Oh and they are both in a P.I.T.A. location too!
-Tim
1 - 10 of 10 Posts
