1 - 16 of 16 Posts
I've noticed this before but I found a pic from yesterday's track event that really shows it well.
Supposedly the IRS setup is not as prone to torque the chassis as much as a solid axle. I have subframe braces, front K-member braces, pinion brace, rear torsion brace, rear cover brace and a rear shock tower brace. New solid motor mounts were installed last year. Tire pressures are religiously checked at the track. Air suspension is shut off at park height.
What am I missing? :confused:
soft shocks? bad sping?? Just throwing ideas out there where to look
You keep torqueing to the left. Stop it.
Looking at the picture, I don"t see the problem. Your chassis is always going to move a little when an engine is bolted to it at WOT. 350+ foot pounds of torque at the crank shaft = 350+ transmitted from the block to the chassis. Is it causing a problem?
Agreed. I don't see any problem except that your front wheels are still on the ground. :D A set of skinnies should help with that. Oh, and that guy on the left has a really dumb look on his face, you should replace him too.
What exactly were you thinking is a problem? Chassis torque? It sounds like you've got it firmed up nicely. I don't think you're missing anything.
"Barbells" are what I call the front wheels, LOL. :D
After further study, it has been concluded nothing is "wrong" and the camera angle is responsible for exaggerating any visible chassis twist.
The dumb look is purely a disquise meant to deceive my opponent. :tongue:
LOL, actually I was referring to the track staff guy standing on the left. But, yea, now that I look again the guy behind the wheel has a dumb look too. Great, deceptive, poker face!
I was looking for the pic of the Mustang with the serious body twist that someone posted in one of the recurring 5.4 threads; That looked awesome, but would be hard to deal with.
Your Mark looks great!
whos bird is that in the back? It looks pretty nice
what size slicks you runnin? mine are 8.5x26x15 on stock t-bird fan blades
ok, thanks, I came across this thread while searching for a solid 8.8 axle setup, and I noticed they looked bigger than mine. You know anything about a solid axle setup? I never really found anything on it for our cars, only mustangs. Thanks
lol, for ride quality, the irs is better, a guy from mod depot said if if put serious power to the car, i needed a solid setup if I planned on racing it often with slicks. the car has 270,000 miles, so i'm sure it would take much to break it.
1 - 16 of 16 Posts
