1995 Cougar
UCA's x2
LCA's x2
Tie Rod Inners and outers x2
Sway Bar end front x2
sway bar end rear x2
strut rod bushings
Thank you. For now this is for comparison purposes. I know that OE prices be higher but if they are supposed to last that much longer then its a worthwhile investment because the above mentioned as a bit of work.
Johnny Bling Bling
in order requested:
$49.80 ea
$127.25 ea
$25.40 ea(inner)
$30.53 ea(outer)
$43.19 ea
$99.55 ea
$85.47 ea(kit for front of strut bar)
$9.00 ea(bushings on control arm side{front})
$8.92 ea(bushings on control arm side{rear})
i can probably get the rear links and control arms cheaper via my napa store.
I'm not sure what bushings you mean by this. Care to explain?
Johnny Bling Bling
on the rearward side of the strut arm, there are bushings that go through the lower control arm. there is a forward one and a rearward one. if you have access to a fax machine, i can fax you a pic.
