Alright, I'm not very technical with the terms or parts... But was wondering if you could help me out here...
I've been noticing a clunking sound comming from the underbody, I've been trying to ignore it for a few weeks, because I haven't been able to afford to fix it.
I looked underneath, and the part that is broken, seems to be a little rod that connects underneath to a part underneath a big coil in my suspension, next to my right back tire. I apologize, I cant be more specific, but I'm sure you can picture it. The rod is clear off the part, and that side sags a little bit. Will I damage anything if I drive it like that for a little while longer, and how much do you suppose it would cost to fix?
thanks.
Baby Huey
Swaybar endlink?
I had the same problem. My sway bar end link bushing fell out and this caused the end link to bang against the sway bar. I caught the problem early and fixed it. I am sure over time the end link would have broken without the rubber busing in place. I would guess that the noise that you hear is the same. It is an easy fix once you find the replacement rubber bushing.
Baby Huey
mine did break the endlink thats why i asked.
