Looking for some help with my suspension on my 35th Ann. SC. I lowered it with Tokico Illumina springs and shocks, new front left and right stabilizer links, new front left and right lower control arms, new front right upper control arm (didn't ripe the seal on the left side), and new rear bushing for the tension struts. Then got it aligned an National Tire & Brake (NTB). I would have rather let a Ford Dealership to it, but they are closed by the time I'm off work and not open on Saturdays. OK, my problem is this, it been a very long time since I have driven the 'Bird before all the installs that I forgot how it is suppose to ride, I just know it is not suppose to ride like this. Plus, I have been driving my rack and pinion Accord all this time. Some of the problems I'm having are the car starts vibrating at 70 mph, when I hit a bump in the road it is stable but not real stable and I feel every single bump. Also, when I'm driving on the highway the steering wheel is heavy in the center position. The best way I can describe it's like have a glass of water that is half filled and you try rocking the water left or right, it kind of floaty unless it is right in the middle. I hope I described my problem clear enough, if not let my know. Any suggestions would be helpful.
What specs did the alignment get set to ? Did they give you a printout on that ??
cheers,
Ed Nicholson
SCCoO
Sorry it took some long to repond. Camber: LF=-0.1, RF=-0.5, LR=-0.8, RR=-0.5 Toe: LF=0.4, RF=0.8, LR=0.09, RR=0.4 Steer Ahead=-0.4 degrees, Thrust angle=0.5 degrees. The guy at the shop said that the caster in the front is not adjustable, is that correct.
hey tbird4ever i just got mine realigned
camber = LF -.03 RF -.7 LR -.6 RR -.6
Caster= LF 5.0 RF 5.2
toe= LF .08 RF .09 LR .07 RR .05
steer ahead 0
thrust angle .01
Your numbers look good compared to mine but did they give you a caster # It looks like you cant adjust it but there might be something wrong in there possibly. I'm not real knowlegible on suspension and alignment but it looks like caster means the angle at which the strut is sitting and were it meets the control. That was a total guess but just my thoughts
