· Registered
I need some help compiling a parts list for the suspension rebuild on my 94. I want to make sure I'm not missing anything.
upgrades I already have (or am about to buy)
-Eibach 1.5 drop springs
-KYB GR2 shocks
-Addco front/rear sway bar 1&1/4
and this list I found by searching, its somewhat old so I want to make sure everything is included? Most of the parts are moog... are there any parts that I am missing or should be motorcraft instead?
Upper Control Arm
LEFT - INCL BALL JOINT K8596
RIGHT - INCL BALL JOINT K8598
Cam & Bolt Kit K8521 x2
Lower Control Arm
LEFT - INCL BALL JOINT K80053
RIGHT - INCL BALL JOINT K80055
Strut Rod Bushing/Kit MOTORCRAFT Frame Side
Strut Rod Bushing/Kit MOTORCRAFT LCA Side
Tie Rod End Link ES3004RL x2
Rear Suspension
*REAR COMPENSATOR LINK K8594 x2
*Sway Bar Link/Kit K8641 x2
*Upper Control ARM TO FRAME K8562 x2
*Upper Control Arm ARM TO KNUCKLE K8588 x2
*Lower Control Arm Kit ** * K8658 x2
· Registered
Discussion Starter · #6 ·
dirtyd0g said:
strut rod?
The sway bar links are not part of the bar, mine are bad and rattle like crazy, the addco will not have the links. The frame bushings may be supplied however.
Alan
?? Yeah, I'm clueless... which is why I've been glazing over all the old threads to try and find a definitive list (a sticky would be awesome). I have never worked on suspension before and I plan on probably having the rebuild work done by a pro. I just want to get all the facts straight and the parts bought before I sacrifice my wallet.
· Registered
Discussion Starter · #8 ·
Ok, so does the rest of the list look complete? Anything else to add?
