I'm attempting to replace some suspension parts on my 1997 LX 4.6 Sport.
From what I can gather from reading this forum, plus using the Rockauto site,
I need to make sure from someone more knowledgable than me that I am ordering the correct parts.
MOTORCRAFT Part # MCS10764 Front Right Upper Control Arm w/ball joint
MOTORCRAFT Part # MCS10763 Front Left " " " " "
MOOG Part # K8680 Strut Rod Bushing Kit Front Suspension @ Control Arm
MOOG Part # K8659 " " " " " " @ Frame
MOOG Part #K8798 Rear Stablizer Bar Bushing to Frame w/27mm bar (2 ea)
Hope you guys that are familiar with this procedure, and the above replacement parts can help me out..........
Brian
The front strut rod bushings from Moog are good for about a year or so.
Those need to be Ford if possible.
One poster here (486Master?) has been running the NAPA parts for over a year, and they're holding up good. Unlike the Moog parts.
Thanks for the info about Moog parts. Will check out the NAPA's.
As you can guess, I'm in the dark about this, just wanted forum members to make sure I'm ordering the CORRECT parts.......
