1 - 1 of 1 Posts
I am installing a T bird IRS assembly in a 1955 Chevy Truck and need some critical measurements to proceed...
I would like to know the measurement from any fixed point on the rear suspension assembly relative to ground... for instance:
What is the distance from the forward mounting bolt head to ground?
.. same for the rear - what is the distance from the rear mounting bolt head to ground?
or
What is the distance from the subframe - any flat portion... like either side of the front or rear diff mount or ??? If I have any of these measurements I can set things up.
as many data points as possible will ensure that I set things up right the first time...
please email [email protected] with any of these measurements.
thank you
dave
Cocoa Beach FL
1 - 1 of 1 Posts
