1 - 10 of 10 Posts
When replacing suspension parts, proper torque is critical.
A little copy and paste, hopefully I have it all covered.
Upper control arm to spindle ball joint - 50-68 ft-lbs
Strut rod to frame & to Lower control arm - 100 ft-lbs
Upper control arm to frame - 75 ft-lbs
3 small nuts to attach front shock assembly (strut mount) to frame - 20 ft-lbs
Front endlinks - 30 ft-lbs
Lower control arm to frame - 150 ft-lbs
Front wheel spindle to Lower control arm ball joint - 84-112 ft-lbs
Front suspension arm bushing joint (tie rod) to Front wheel spindle Nut 51-67 ft-lbs
Stabilizer (sway) bar link to Front wheel spindle - 30-40 ft-lbs
Lower shock absorber to Lower control arm - 125-170 ft-lbs
Tire lug nuts - 100 ft-lbs
Spindle nuts - Both front and rear - 188-254 ft-lbs
Lower shock absorber bolt - 95-126 lb-ft.
Upper rear shock absorber - 27-40 lb-ft (with ARC) 44-58 lb-ft (without ARC)
Upper rear suspension arm to sub-frame - 51-67 ft-lbs
Upper rear suspension arm to rear knuckle - 110-148 ft-lbs
Lower rear suspension arm to sub-frame - 166-202 ft-lbs (front)
Lower rear suspension arm to sub-frame - 142-199 ft-lbs (rear)
Lower rear suspension arm to rear suspension compensator link - 110-148 ft-lbs
Lower rear suspension arm to rear wheel knuckles - 110-148 ft-lbs
Rear stabilizer (sway) bar link to lower rear suspension arm - 8-9 ft-lbs
Rear stabilizer (sway) bar link to rear stabilizer (sway) bar - 35-46 ft-lbs
Rear stabilizer (sway) bar bracket to sub-frame - 25-33 ft-lbs
If I missed anything just chime in!
Good call Joe. :thumbsup:
This should have been done a long time ago.
Tire lug nuts should be 100 ft lbs. (At least that's what I set mine at)
That's what I set mine at Ron, I was just going by the specs I found.
maybe i'm just not seeing it in their, but do you have the specs for those bolts holding the K-frame in? i know mine came loose on my old 90bird, pretty sure my dad just hammered on them with an impact. at least it stopped clunking :p
Subframe bolts I believe are 100 ft. lbs.
According to my disc manual:
Description Nm Lb-Ft (Lb-In where noted)
Front Suspension Lower Arm to Sub-Frame 113-153 84-112
Front Suspension Lower Arm to Front Shock Absorber 170-230 126-169
Front Wheel Spindle to Front Suspension Lower Arm Ball Joint 113-153 84-112
Front Suspension Lower Arm to Front Suspension Lower Arm Strut 113-153 84-112
Front Suspension Arm Bushing Joint to Sub-Frame 113-153 84-112
Front Suspension Arm Bushing Joint to Front Suspension Upper Ball Joint 68-92 51-67
Stabilizer Bar Link to Front Wheel Spindle 40-55 30-40
Stabilizer Bar Link to Front Stabilizer Bar 40-55 30-40
Stabilizer Bar Bracket 53-72 39-53
Front Suspension Lower Arm Strut to Sub-Frame 113-153 84-112
Front Shock Absorber to Upper Front Shock Absorber Mounting Bracket Nut 50-71 37-52
Upper Front Shock Absorber Mounting Bracket to Body 22-31 17-22
Tie Rod End/Rod or End to Front Wheel Spindle 53-73* 39-53*
ABS Sensor 4.6-6.8 (41-60 lb-in)
Brake Hose Retaining Bolt 11-16 9-11
Lug Nuts 115-142 85-104
Front Axle Wheel Hub Nut Retainer 255-345 188-254
Front Disc Brake Caliper/Anchor Bolts 132 97
*Tighten to minimum torque, then continue to tighten until aligned to nearest cotter pin slot.
DRIVESHAFT—PINION ANGLE SPECIFICATION Axle Angle Controlled Height
mm Inches
8.8 inch 2 degrees 18 minutes 152.9 6.02
Upper Rear Suspension Arm and Bushing-to-Sub-Frame Nut 68-92 50-68
Upper Rear Suspension Arm and Bushing-to-Rear Wheel Knuckle Nut 149-201 110-148
Lower Rear Suspension Arm and Bushing-to-Sub-Frame Nut (Front) 225-275 166-202
Lower Rear Suspension Arm and Bushing-to-Sub-Frame Nut (Rear) 192-259 142-191
Lower Rear Suspension Arm and Bushing-to-Rear Suspension Compensator Link Nut 149-201 110-148
Lower Rear Suspension Arm and Bushing-to-Rear Wheel Knuckle Bolts 113-153 83-113
Upper Suspension Arm-to-Sub-Frame Nut 68-92 50-68
Rear Stabilizer Bar Link-to-Lower Rear Suspension Arm and Bushing Nut 10.2-13.8 8-10
Stabilizer Bar Bracket-to-Sub-Frame Bolt 34-46 25-34
Rear Stabilizer Link-to-Rear Stabilizer Bar Nut 46.7-63.3 35-47
Shock Absorber-to-Lower Rear Suspension Arm and Bushing Nut 128-172 94-126
Shock Absorber-to-Body (Upper Mount) Nut with Ride Control 37-54 27-40
Rear Axle Wheel Hub Retainer Nut 255-345 188-254
Rear Brake Backing Plate-to-Rear Wheel Knuckle Bolts 59-80 44-59
Lug Nuts 115-142 85-105
Rear Disc Brake Caliper-to-Knuckle 98-132 73-97
And for anyone interested in frame specs, my disc manual says:
Front Sub-Frame-to-Body Through Bolts 97-132 72-97
Stabilizer Bar Links-to-Front Wheel Spindle Retainers 55-75 41-55
Lower Arm Inner Pivots-to-Front Sub-Frame Retainers 125-170 92-125
Front Suspension Lower Arm Struts-to-Front Suspension Lower Arm Retainers 120-160 89-118
Front Spring and Shock-to-Front Suspension Lower Arm Retainers 140-195 103-144
Rear Sub-Frame-Body-Insulator Retaining Bolts 98-132 72-97
Rear Sub-Frame Stabilizer Bracket Retaining Bolts 47-63 35-46
Rear Axle Differential Front Insulator Bolts 77-104 56-76
Rear Differential Insulator Horizontal Bolt Plate Assembly Retaining Nuts 102-122 75-90
Rear Axle Differential Insulator-to-Rear Sub-Frame Bolts 77-104 56-76
Steering Coupling Pinch Bolt 28-40 21-30
Tie Rod End-to-Front Wheel Spindle Retainers 53-73 39-54
Front Engine Support Insulator Through Bolts (3.8L) 47-68 35-50
Front Engine Support Insulator Through Bolts (4.6L) 47-63 35-46
Driveshaft to Rear Axle Universal Joint Flange Retaining Bolts 95-130 70-96
Reinforcement Rod-to-Front Sub Frame Retaining Bolts 97-132 72-97
Do know what the torque spec on the Stabilizer (sway) bar link to front sway bar is?
You only have the torque spec for the connection to the spindle
Go easy on those end link nuts. Over tighten and you will be removing it next time with a cutoff wheel. Ask me how I know.
Al
1 - 10 of 10 Posts
