Ig to a friend with a good loking 88 turbo coupe with a toasted motor. He has a 351 he is going to put in it. can you give any details or poiters or suggestiosn on doign this on what type of incompatibilites that we may run into. thank
Regg
Carborated 351 1970s vintage with a performer intake cam and carb. thanks
I know the firewall on my 85 had to be slightly modified on the passenger side to fit the manifold but I have a Cleveland so if that's what your friend has I think that's the only thing you have to look out for fitment wise. I'm not sure about mechanical problems right off hand although my car does have a push button start so the ignition might be something to look out for.
Matt
A carbed setup will more or less fit the same way the 302 does. With a TC though, the driver's side valve cover may interfere with the ABS. With a high-rise intake, the air cleaner will interfere with the hood. A single plane might help you escape getting a cowl hood.
Mine comes very close to hitting the stock M/C.
