1 - 14 of 14 Posts
Will I need anything else from the 97? Can I just use my fuel rails, and what about my T-Stat housing? Thanks a lot,
Preston
Discussion Starter #2
Also, where is does the line go on the 94-95 for the power break booster, if there is even one? I want to get a ported mustang upper, but I don't want to have to tap into it. Thanks again,
Preston
I don't have the equipment or knowledge to port it, so I figured I would just buy one from the corral or eBay.
Preston
You have a new PM by the way.
Does anyone know?
Preston
I was going to do the same swap, my prob. was I couldnt find a t-bird upper. I tryed to order one from the ford place, thay said it was obsolete,but yet I was abel to get the lower, ( no good without a upper). I'm just going to find someone to port my elbow from my 94-95. Sents the heads on a 94-95 wont flow enymore then the intake,Its a wast to do the 95to96 intake swap. I didnt know this at the time I was trying to do the swap. So unless you do a head and intake swap its better to just port the intake elbow.
FASTFORD!!
You don't have to find a T-Bird upper, you can adapt a Mustang upper. From what I've seen the 96-03 uppers will work.
Preston
Refrigerator Raider Hater
But I'm not going to that intake, so wouldn't my stock fule rails just bolt on. I figured that I would need to do something with the accelerator cable, but other than that I don't see why I can't use the rest.
Preston
I just figured that I would upgrade it all a little bit, plus I can use the ported upper plenum, which I know isn't worth much, but it's better than nothing.
Preston
Also, will the 96-98 fuel rails and T/B from a mustang fit? There are alot of these on corral for pretty cheap.
Preston
yes the stang rails and TB will work. ou can use their plenum too, you'd just have to tap it for the vacuum assitied brakes.
1 - 14 of 14 Posts
