1 - 19 of 19 Posts
It's time to replace my sway bar bushings, so I am considering replacing the sway bars with addco bars.
What are people running and how do they like them?
Anyone with the Addco 1 1/4" package? Who do I order Addco from?
PJ
I have it and she works great , You can order direct from them. http://www.addco.net/
<a href="http://s245.photobucket.com/albums/gg77/POSSUM61/?action=view&current=SWAYBAR001.jpg" target="_blank"><img src="http://i245.photobucket.com/albums/gg77/POSSUM61/SWAYBAR001.jpg" border="0" alt="Photobucket"></a>
Yes. 1-3/8" is serious overkill. It is also to big to be compatiable with the stock front bar.
The largest size that is compatiable with the stock front bar is the 1-1/4". Given that the front is such a PITA to change I highly recommend just getting the 1-1/4" for the back and calling it a day.
i was thinking about taking the front to a shop to have it done. im too lazy to do it myself.
how about 1-1/4 rear and 1-3/8 front? still overkill?
That would work but yes, still overkill IMO.
It all depends on why you're doing it. Do you intend to autocross or do you just want bragging rights to the biggest bar?
I have both 1.25 f and r addco. The rear made an improvement and I had poly bushings on the stock front bar at the same time. THe body roll was dramatically reduced.
I later added the front bar which is a lot of work but wtf why not do it if you have never seen it dun before. I learned a lot about my car doing it but that not for everyone.
The front you need to drop the K and suspend the engine which alone is a hassle.
THe addco plates and bushing aren't always perfectly made either so watch out for that.
I will say the combo of the 1.25 f/r is enough to really wake up the handling those 1 3/8ths have to be rough riding.
I would get equal sized bars so if you plan on not changing the front get a 1 1/8ths addco bar for the rear I think I would have liked that better than the bigger rear bar with the wimpy stock front bar.
But the best street combo I think is the 1.25 front and rear, its really at the limit of comfort. I ride on 16" sc wheels so peeps with a lower profile tire have it rougher.
Splattered, thanks!
I will be pulling the engine in the next couple of months- thought about doing the front sway then since the bushings are toast. 1.25 all around seems the way to go. With engine out, do I still need to drop the k-member? Also, with short endlinks in the rear, should the e-brake cables go under or over the sway bar?
PJ
Yea do not by the 1 3/8 to much stress on the car
So, what if you plan to run the car on a road/race track?
Splattered, thanks!
PJ
With no engine its easy you dont have to drop the K. Just cork screw it out from one side. I did it on an SC with no motor.
I wouldn't know about running the e brake differently just run the same as stock because I know someone with a lowered SC with short links and an addco bar in the back and he didnt mention touching the ebrake.
His user is solow but he hasn't posted in a while
1.25 f/r is really a fun combo one of my favorite things I have done.
People running the 1 3/8ths can lift a tire off the ground on a steep driveway so yeah big time stress. Btw I have f/r shock tower braces SC backseat L braces and the lower engine cradle brace. I wouldn't go with the big bars without some bracing.
I have F&R 1 3/8" bars on my SC and have for several years now. I recently installed F&R 1 1/4" bars on my LSC. Both are lowered, and in both cases, the parking brake cable continues to go under the rear bar.
Heavily Medicated Crime Fighter
I would not change my prototype 1 3/8" F/R bars for the world and the ride is not all that bad. If you have a lot of potholes where you live then go with the 1 1/4" F/R bars. I know a little something about these bars so you can take my advice to the bank ;)
Mark
thanx for the help everyone. i think im gunna take the popular opinion and get the 1-1/4" bars. i think that it will combo up nicely with a set of koni's. the potholes that we have in northeast ohio can be killer and im not trying to go too crazy with the suspension. just trying to make it a little more crisp. i hate how it rides on the highway right now. i have some minor subframe bracing right now and im planning on getting the front strut tower brace this spring. does anyone make one for the rear? if not i will have to build one. it looks to be pretty simple in the rear.
thanx for the help everyone. i appreciate the input. :xpD:
Here's my .02: A lot depends on "where" you're going to do the majority of your driving.
If you are in an area with lots of pot holes, speed bumps, bad roads, etc, I would not recommend the 1 3/8. If you are going to see sweeping turns on on-ramps, back roads, etc. I think the 1 3/8” are perfect.
I had 1 3/8 F&R on my T'Bird with Eibachs and absolutely loved them (However, I DID NOT love the poly bushings on all four corners!!). I now have the 1 3/8 on the rear of my LSC, but haven't put a lot of miles on it but so far I like it. I will soon be putting the front 1 3/8 on, just haven’t gotten around to it yet.
I do recommend that if you go with the 1 3/8 F&R, some type of frame bracing should be considered because as mentioned before, it is possible to lift a wheel on driveways. (And that isn’t a good thing if you don’t have posi…. :zwall: )
But remember, the sway bars are just along for the ride until the suspension changes. And “how” the suspension changes determines how the bar diameters affect the car; did the suspension change due to a pot hole/bump or due to weight transfer… or both.
Anyway, just my .02 and I like my 1 3/8”. :D
does anyone make beefed up end links for our cars? for a while i saw that summit racing had some moog's but i dont see them on there anymore. and i think they only had rears. just curious
1 - 19 of 19 Posts
