i was wondering what the difference in peformance was from the different sizes of the swaybars? i am looking to get a set but am not sure exactly what size i am looking for. also what would you compare the ride quality to with the different size bars?(when i say ride quality i mean does it ride like a truck when you are going straight down the road?)
MaleWhore
i was about to post the same question...
Swaybar sizes
That gives you the swaybar sizes. The difference between the addco bars and your stock front bar are:
1 1/8 - 27% stiffer
1 1/4 - 94% stiffer
1 3/8 - 183 % stiffer
The stiffness is the diameter^4 assuming the bars are both solid (which the V8 bars are). I can only tell you numbers because I haven't got my bars yet. The rear bars are going to have even stiffer percentages in comparison to the addco bars. I don't remember what the formula is to change the torsional stiffness into spring rate right off the top of my head. Maybe someone will give a response on the increased stiffness on the street, but I think it will depend on the person as to how harsh it really feels to them.
Russell
MaleWhore
which size would you guys recomend?
I guess it really just depends on what you want. I am going with 1 1/4 f/r kit. I know Mark M. loves his 1 3/8 f/r kit. If I had a choice I would rather use a 1 1/8 rear sway bar with the 1 1/16 front bar and use springs to increase roll stiffness, but since that isn't an option I have decided to bandaid the situation with 1 1/4 bars. I really wish that I could help you but I would say if you could find people that different swaybar setups on their car and drive their cars then you would probably be able to tell what you wanted better based on ride harshness and road handling. Sorry I can't be of any help.
Russell
MaleWhore
well, so far u have been great help...from what i understand, the bigger the tubing, the stiffer the car bodyroll resistence, am i right, and as you say, 1.25 does seem like a perfect everyday drivers better choise.
Yes.
The object of the swaybar is to keep the weight from loading up on the outside tires. When you go through a corner I am sure you can feel the weight being transferred to the outside tires. You can use swaybars to match the front and rear outside tire loading. Having the front and rear sway bars matched ( not necessarily the size but their effectiveness) is important as well as a 50/50 distribution. Basically what I am saying about the effectiveness is the front bar might transfer 500 lbs, then you would want the rear bar to transfer the same amount of weight (given a 50/50 weight distribution). That would keep the car handling neutral through the middle of a turn with no oversteer or understeer. So if you make the front and rear swaybar (effectiveness) matched then a big sway bar such as the 1 1/4 bars would approx. half the degrees of body roll (ex. you have 4 degrees of body roll, now you have 2 degrees = big increase in cornering power) that your car experienced, which would keep some of the weight off the outside tires (which are the important tires in cornering). Every tire has a performance curve that has "traction available v. weight on the tire". It is not a linear relationship. So for example if you put 500 lbs on the tire it might have 625 lbs. of traction available which would give a g rating of about 1.25g's, but if you put 1000 lbs on that tire it might only have 800lbs. of traction available which would result in .80g's. This is of course assuming the tires can handle the traction. This is a VERY general example but I figured maybe this could help you understand what the purpose of swaybars really are. Tires will all have different performance characteristics but the important thing is realizing the principles behind the tire's ability to hold on to the road. I will talk more later if you have more questions, but I think that is plenty of reading for the moment.
Russell
MaleWhore
thats is a very good detailed explanation...tell me how it goes when you get the sways installed on your car...getting them soon as im planning on getting new brakes since they are shot now. i see you guys are getting the cobra brakes, pm me where u guys are getting them from...and thanks a lot, you been great help so far
