1 - 2 of 2 Posts
Hey guys, I ran into an issue today trying to install my SC 5-speed center console. I am running an MGW shifter on my car and I had been using the stock auto console with minor rubbing in 5th gear. Well, the shifter hits the SC console in 2nd and 4th pretty bad so I can't use it. I contacted MGW to see if they can get me a shorter (horizontally) handle. I was just wondering what shifters you T-45 swap guys are running and if you have any issues with rubbing. Thanks.
Discussion Starter #2
Just in case any of you 5 speed swap guys ever run into this issue, I ended up using the handle that MGW makes for a 2005+ V6 Mustang with a T5. Fits the SC center console almost perfectly and the feel of the shifter is as good as or better than the regular MGW handle.
1 - 2 of 2 Posts
