Are the t-45 transmission output yokes the same as our auto's and is the input shaft on the t-45's able to wiggle around alittle or do i have a bad bearing in mine.
Tou will need a T-45 yoke. And the output shaft shouldnt woble. The input shaft might have a tad bit of play in it. I strongly suggest you buy a new imput shaft bearing and replace it if you bought he trans used. What year and model is your transmission. Chris
You will need a driveshaft that is 1.5" shorter than stock, using the T-45 yoke. Give me your email. And search on this forum. I have written a lenghty Notes file on my swap that has all the info you will need From my swap. Chris
You have mail. I had a few people whos email's were not sent due to Unknown email reaturs or full boxes. you may have been one.
