1 - 2 of 2 Posts
I own a 94 4.6 bird, and I am wanting to do the auto to manual tranny swap. Mustang parts specialist is advertising a complete auto to T-45 tranny swap kit. I called on it and comes complete with everything, and I mean everything. The thing is the kit if for Mustangs. My question is does anyone know what will not work from this kit? What will I have to go an do or purchase?
Sheepish
You'll still have to custom build your own shifter box and put it on the tranny. Otherwise the shifter will be in the same space as your stereo. You don't wanna have to reach that far forward, and into your dash to shift do you?
I don't know how well a mustang clutch pedal assembly will fit and/or work. Papajohn recommends using the hydraulic clutch system for a TBird SC. He made a nice big writeup on the T-45 swap and its under the Transmission tech articles. check it out. He shows you how to build that shifter extension box and everything.
Good luck on putting a T-45 in your bird. Wish I could afford to have 5 gears. :)
1 - 2 of 2 Posts
