1 - 18 of 18 Posts
Discussion Starter #2
bumpity bump
someone make a offer i dont need this taking up space
whats your email address ill gladly send you a pictures
im 95% sure its out of a 97 sho youll be able to see from the pictures
mileage reading is 130.188
if you want to get technical...
96 has yellow km/h numbers and needles, and has a shifter indicator
97 has the same faces as the 96, but the shift indicator is deleted
98 has the same faces, but the km/h numbers are white instead of yellow
99 has the numbers spaced out by 20 instead of 10, red km/h numbers, red needles, and a silver bezel
:D
well then its a 1996 cluster because it has the shifter indicator
christmas special $40 shipped or its going to ebay
easy as pie, you dont use the whole SHO cluster, you use the SHO speedometer, tachometer and fuel/temp gauges and just swap them into the 97 case.
BTW, you must have a 97 for this to work. or you must be inclined to make a 97 cluster work in your 89-96...
Sent PM.
Discussion Starter #16
pm returned
yes you swap the guages into the 97 case i see that your have a 97 so you would have no problem doing the swap
35 shipped is a great deal on this ive sold quite a few for $60 or more
1 - 18 of 18 Posts
