1 - 20 of 47 Posts
I've talked to Justin at fore Innovations today, about building a fuel hat for the 92-97 birds, the fuel hat will consist of a pair of wires for both pumps or single pumps, it would also accomandate the oem level sender, the fittings will accept 8an and u would be able to use oem line adapter which they sell just need to get a head count, I can make it happen if there is enough interest, price I'm guessing like a cobra hat 400-450 range, I know I want this, I'm sure there is others, this will be completely e85 compatable, lets here your input guys
Robert
Ok I'm definitely in if the price is right, it would keep me from ditching the fuel tank. I've been thinking hard about it.
Baddest N/A NPI in Canada
This works for the single 405 LPH pump that you sell? I am interested...
Discussion Starter #4 (Edited by Moderator)
Yes will work with single or double same hat will do both.
There's not alot of interest here but, it's still getting built. This fuel hat will be the way to go.
Robert
Any word yet on production or pricing for this hat?
Yes pricing is gonna be 400-435 jus like a cobra hat
Got word from FORE Innovations he will be starting our fuel hats
I'm extremely excited about this, if u guys have not seen his work go to www.foreinnovations.com
Robert
When are these going to be available? I want one for my car...
Ill update this Monday with more info
Hopefully next week he will be started on them the gtr hat is almost done
Robert I'm interested in at least one of these assuming it is compatible with a pair of Stealth 340 pumps. Would really like to see more details on how this is going to be done as far as the wiring connections, fuel level sender and the pressure and return ports, before committing.
Will there be individual supply ports or just one 8AN supply with pumps joined inside the tank ?
David
It will be joined inside the hat it's self there will be no hoses, it will have the option for stock line adapters or 8 an fittings it will have option for dual or single pumps, it will have 2 pairs of wires for each pump, will still have place for stock sending unit and will accept 340s
Robert
I'm interested in this. I'm actually wanting to talk to you about a full return style setup from the pump to the injectors for my 4v rebuild.
Discussion Starter #15
Okay we'll just send me a pm we can set that up very easily
Robert
Guys not sure if this is it , But Robert can chime in. If not the right one I will replace ;)
Edit: Sorry just trying to help a friend out .
That's not it. That's a Fuel Pressure Regulator.
It's apparently still in development / mfg. stage...
1 - 20 of 47 Posts
