Maybe I didn't do the right search, but I couldn't find anything about this question.
I have '94 T-bird with 3.8 v-6. I am in need of new TC but what will be the best one to use? I did go to the tech section and look at the TC spec. From what I understand, the best oone to use is the 11' converter but not avail. to my spec trans (or more like my engine). See couple 12' converter but I don't know which one to use. It will be most likely be use as stock with little modification( more like improvement) over the stock but want to use the best (at least best stock) converter for the buck.
Trans is stock unit with trans cooler and updated 1-2 and 2-3 accmul. with stock deep sump pan.
As always, thanks for your input and time.
Toshi
Toshi,
This might help you.
talk to DirtyDog he's a god
