1 - 20 of 20 Posts
I am looking for something better than stock. I wanted to get a MarkVIII TC but I can't find anything saying if it will work or not. Just need some info. on what may work or not. Thanks.
Don't take my word on it, But i have heard that the MK8 and Maruauder TC's will work on our cars if we use the MK8 Flexplate.
Fry Rice Specialist
it will.
Astrophysicist / PostWhore
A Marauder converter will bolt up to a 3.8L? :confused:
If so, that would probably be a heck of an upgrade, as the stall is nice for the price.
Fry Rice Specialist
only on 3.8 with the 4r70w and also mark 8 flexplate.
get a converter for a Stock 99+ mustang V6 converter they stall at ~2200rpm instead of ~1800rpm like the stock unit.
Or on an AOD with the wide ratio gear set (aftermarket) as it has the 4r70w input shaft.
I'd rather have a Marauder TC for the time and money it's going to take to put one in, it's not worth it to buy a 99 V6 Mustang TC, the marauder TC is a very good deal for the money you spend on one.
Confirmed V6 Nut
Green95LX,
Mind expanding your answer?
I am contemplating an upgrade to my TC. In the Tech articles it was mentioned the right match of TC can drop your 1/4 time by up to a second.
I'm not looking for a food fight here. Let's look at the numbers and then the reasoning for each choice.
I've got one additional question. What is there in the way of aftermarket TC for street and strip applicable to the 3.8L?
mark viii tc = 2200-2600rpm stall
marauder tc = 2600-3000rpm stall
PI stallion converter = 3200-3500 rpm stall (or more dunno)
marauder tc is best for a cheap choice. But if you're serious about going fast with a 4r70w tranny, then get a pi stallion converter for 3200rpm.
-Thomas
With any of these upgraded TC's is a new input shaft or anything else really needed besides the flexplate.(have a trans cooler and temp gauge) Also I was looking at 3:73 trakloc.
With these two upgrades should I see a good improvement in acceleration?
Confirmed V6 Nut
Thomas,
Is the 99 Mustang TC the same as...?
If it's different, where would it fit in the list you posted for stall range?
the 99 v6 converter is the same as yours. the 99 GT converter is the same as the mark's.
I agree with thomas here, if you're looking for a budget converter. The Marauder TC is the best value. If you're seriously into racing then look into a PI Stallion converter or a Morris converter, Which is what JL uses if i'm not mistaken.
Jedi Master
agreed, maruader tc all the way with mark viii flex plate
along with the j-mod , a nice tranny cooler, 93 mark viii one piece aluminum ds and chip and you'll have a killer set up
all parts are from 150-320 price range
Whats the stall on a 99 v-6 Mustang TC compared to a 97 V-6 T-bird?
Confirmed V6 Nut
Thomas,
You used a range of stall speeds for the converters. Are they adjustable before installation or that's they way they work?
depending on the amount of torque you make will depend on the stall the converter engages at.
1 - 20 of 20 Posts
