1 - 20 of 123 Posts
All Time / Lifetime / Personal best times go in this thread.
This list is for those of you who haven't seen better times in years. :tongue:
If you haven't set a new personal best in a while we'll put your time on this list.
*Everyone who races their car should be striving to improve upon or at least maintain a good track time with their cars.
The current times list will be maintained in THIS THREAD. If you've run your car recently please post your time to the linked thread. If you've run a new personal best please make that known and I'll also add the time here or update your existing time to the new best time.
I'm going to try to get everyone who's ever run their car and wants to be on the list into their time bracket.
In order to keep the list from becoming cluttered the following *exceptions apply:
  • If you sell the car your name is coming off the list
  • If your car has been wrecked and will never run again your name is coming off the list
*Exceptions subject to moderator determination and subject to change.
I'll break it down into time brackets so that there will be competition (and bragging rights) among each group.
Groups will be:
  • 9 and 10 second cars
  • 11 second cars
  • 12 second cars
  • 13 second cars
  • 14 second and above cars
These lists will always be for 1/4 mile times only. I'll post up an example format, and you can reply to this thread or PM me in that format and I'll copy and paste.
Must be a Ford MN12. Any power adder, any tire, any motor, don't care. There's really not many rules here, just a list to show the top, all-time fastest MN12's (you driving your car!). I don't need pics of time slips, Ill take what I'm told. If you see BS from someone, I'll already know it and it won't get on the list. One entry per car. You can comment and post in here also.
Here is the format: 11.062 @ 123.17 - 06/2012 - Blown38 - 95 T Bird SC AR
Start with your time to the third decimal place and MPH to the second decimal place followed by your user name, year of car, Type of car, Basic Engine info including size (3.8L or 4.6L) - 2 valve or 4 valve, power adder(s) and finally the month and year of your run.
I'll continue to update and tweak these lists as time permits and new times are posted.
So without further ado ...
THE ALL TIME FASTEST MN12's in the country
9 - 10 SECOND CARS
  1. 09.956 @ 135.12 - 11/2014 - Brian Oatway (SCrazy) - 94 T-Bird SC C4 Auto, 3.8L 2V with 2.6L KB - See the video HERE. - The Fastest 3.8L MN12 in the World!
  2. 09.985 @ 132.74 - 01/2013 - RobertP - 95 T-Bird LX - 4.6L TrickFlow / Vortech T-trim / on E85 - See the video HERE - The Fastest 4.6L MN12 in the World!
  3. 10.020 @ 136.70 - 11/2012 - Mike Siska (EECDOC) 95 T-Bird LX 4.6L - Allen/SC
  4. 10.048 @ 138.99 - 09/2011 - David Neibert – 93 T-Bird SC 347/turbo - Highest Trap MPH
  5. 10.083 @ 130.10 - 11/2012 - Kevin Leitem - 90 T-Bird SC C4 MPX
  6. 10.454 @ 134.56 - 12/2016 - neverfastenough - 90 T-Bird SC 232ci V6, Stock split port heads, custom intake, Single Turbo
  7. 10.740 @ 126.83 - 11/2010 - Blown38 - 95 T-Bird SC 2.0L AR
  8. 10.878 @ 132.06 - 04/2017 - Bulldog - 97 Tbird 4.6 2v/2.3L TVS @ 21lbs boost on E85
  9. 10.907 @ 126.98 - 05/2015 - no164ford - 35th Anniversary SC 2.3 TVS
  10. 10.910 @ 125.61 - 08/2017 - David Neibert – 91 T-Bird SC 2.3 Whipple
  11. 10.956 @ 122.XX - 10/2011 - CobraRThunder - 97 T-Bird 4.6L - TEA Stage2 PI Heads, VTStage3 blower cams, Vortech SC @ 15 psi w/ 3.12" pulley on 93 pump gas
11 SECOND CARS
  1. 11.153 @ 120.19 - 12/2010 - Nickleman60 - '94 T-Bird SC - MPX/N2O
  2. 11.280 @ 123.00 - 06/2019 - MikeB - 1997 Thunderbird Sport - 5.0L-2V PI S/C - 540 RWHP / 492 RWTQ
  3. 11.335 @ 122.43 - 11/2018 - Ron R. (Trunk Monkey) - 95 T-Bird LX with 5.3L, 2V/Trick Flow Heads with SVO on E85
  4. 11.388 @ 118.68 - 11/2007 - 96 GoldBird - '96 T-Bird - Vortech Intercooled T-Trim, Renegade PNP SVO Intake, Last Set of Jim's PHP NPI Heads, Crane Cams, Renegade built Short Block, and a bunch of other stuff.
  5. 11.397 @ 118.87 - 12/2016 - Dave Dalk (XR7 Dave) 92 AOD 5.0 Turbo T-Bird
  6. 11.470 @ 118.27 - 12/2008 - Han Solo - 94 T-Bird LX - 4.6L, Ported PI heads with SVO
  7. 11.521 @ 116.75 - 11/2010 - Kurt K 92 T-Bird SC - 2.0 AR AOD
  8. 11.561 @ 117.52 - 03/2012 - ricky05uphs - 96 T-Bird LX 4.6L 2V/Explorer Engine with SVO, 35 HP Nitrous shot and E85
  9. 11.598 @ 119.16 - 05/2013 - Miller - '94 SC - 1.7 AR @ 22 psi boost with bigger inlet + 95mm TB - on 93 pump gas
  10. 11.631 @ 119.14 - 11/2008 - Ira R. - 95 SC 5-Speed with 1.7 AR
  11. 11.648 @ 119.6_ - 09/2012 - kenewagner - 93 T-Bird SC 2.3 Whipple
  12. 11.676 @ 121.35 - 09/2012 - rzimmerl - 90 T-Bird SC - 1.7AR AOD
  13. 11.723 @ 114.81 - 11/2013 - no164ford 1990 T-Bird SC 35th M90
  14. 11.735 @ 118.36 - 09/2012 - John Ludorf - 94 T-Bird SC 2.0 AR, T56 6-Speed
  15. 11.750 @ 113.72 - 05/2012 - 1MTNCAT - 96 Cougar XR7 4.6L PI/2V N2O
  16. 11.770 @ 113.20 - 02/2018 - R429460 - 95 Cougar XR-7, N/A 5.3L Big Bore 4.6L with 2V Trick Flow Heads on E85 - Fastest N/A MN12
  17. 11.879 @ 112.42 - 11/2014 - cas23 - 90 T-Bird SC C4 Auto 3.8L 2V with MPX @ 25% OD
  18. 11.956 @ 113.17 - 11/2013 - XR7 Phillip - 90 Cougar 5-Speed MPX-S
  19. 11.971 @ 112.75 - 12/2013 - ThunderChecken - '96 T-Bird LX 4.6L 2V/PI/SVO, Meth Cooled on 93 pump gas
12 SECOND CARS
  1. 12.030 @ 109.__ - 09/2010 - ScrapSC 1990 T-Bird SC, AOD MPX - 2010 Shootout
  2. 12.097 @ 114.15 - 11/2013 - Racecougar - 90 Cougar XR7 5.0L 4V w/Kenne Bell 2.1L SC, Meth cooled on 93 pump gas
  3. 12.121 @ 109.25 - 11/2012 - Justin89SC - 95 Tbird LX 4.6L N2O
  4. 12.150 @ 112.05 - 04/2010 - joker77_2005 (Mike Napier) - 1989 Cougar XR7 5.0, N2O 5-speed
  5. 12.158 @ 103.__ - 09/2012 - Quik95SC - 95 T-Bird SC MPIII
  6. 12.160 @ 111.77 - 02/2007 - Johnny Langton 4.6L NPI N/A
  7. 12.177 @ 114.08 - 01/2012 - Modularbird - 96 T-Bird LX (The Silver Slut) - 4.6L Built PI w/Vortech S-Trim
  8. 12.332 @ 111.69 - 04/2014 - Mike Puckett - 90 T-Bird SC 3.8 2V 5-Speed
  9. 12.401 @ 112.38 - 07/2013 - Alan (ALS35) 93 T-Bird SC MPX
  10. 12.410 @ 103.95 - 07/2009 - VicRattlehead - 96 T-Bird 4.6L N2O
  11. 12.440 @ 112.54 - 07/2007 - JasonMiller94SC - 94 T Bird SC N2O
  12. 12.455 @ 111.05 - 09/2012 - Mikessupercoupe- 94 T-Bird SC 5Spd 1.7L AR
  13. 12.492 @ 109.56 - 08/2011 - TGJ 96 T-Bird Sport, 5.0L 2V Big-Bore NPI N/A
  14. 12.660 @ 104.30 - 10/2014 - Sarah Lichtsinn - 95 T Bird SC MPX
  15. 12.634 @ 111.92 - 10/2012 - mywhite89-89sc 5-speed 1.7 Autorotor
  16. 12.680 @ 107.62 - 10/2014 - DrFishbone - 1989 Tbird SC - 5-Speed/MPXs
  17. 12.701 @ 107.71 - 08/2011 - Rick Bender - 95 T-Bird 4.6L 2V/PI/N2O
  18. 12.725 @ 101.35 - 10/2014 - nasty V6 - Scott Bruhn - 94 T-Bird SC Auto
  19. 12.816 @ 106.36 - 05/2014 - scnut80 - 92 T-Bird SC Auto 3.8L 2V
  20. 12.891 @ 105.83 – 10/2009 – Jimmy 2Coupes – 95 T-Bird SC – 3.8 5 speed, Heads, Cam, MP1 M90
13 SECOND CARS
  1. 13.101 @ 101.07 - 04/2006 - MaddMartigan - 93 T-Bird LX
  2. 13.110 @ 105.01 - 08/2012 - ShadowDragon - 97 T-Bird LX, 4.6L 2V/Allen AED
  3. 13.173 @ 103.40 - 04/2012 - Super Duper Cou - 93 T-Bird SC
  4. 13.180 @ 105.68 - 11/2010 - PAHTBRD - 97 T-Bird LX, 4.6L 4V/Vortech
  5. 13.238 @ 103.37 - 04/2006 - OxmanWI - 96 T-Bird 4.6 SC AED
  6. 13.467 @ 102.75 - 08/2011 - Joe Thierry - 95 T-Bird 4.6L 2V/NPI/N20
  7. 13.482 @ 100.23 - 11/2010 – Jimmy 2Coupes – 94 T-Bird SC – 3.8 4R70W, MP1 M90
  8. 13.542 @ 104.79 - 08/2012 - Karen Irvine - 95 T-Bird 3.8L SC
  9. 13.583 @ 103.74 - 10/2014 - Chris_Murder - 96 T-Bird 4.6 4V N/A
  10. 13.600 @ 099.46 - 10/2003 - Joel Bender - 96 TBird LX 4.6L/N2O
  11. 13.717 @ 104.42 - 10/2012 - 91BLOWNBIRD - 91 TBird SC MPX
  12. 13.726 @ 096.45 - 10/2003 - 06 GoldBird - N/A with Renegade PNP Heads, Comp Cams, Stock Tranny, Cobra 3.73 Rear, Kooks, etc.
  13. 13.825 @ 098.94 - 09/2014 - Mgino96tbird46 - 96 T-bird LX 4.6L 2V, PI Intake with Trick Flow heads on NPI short block - 93 octane
  14. 13.850 @ 096.50 - ??/2008 - 95badbird - 95 T-Bird LX Superleggera, Stock 351W, N/A
  15. 13.957 @ 097.58 - 10/2015 - theterminator93 - 97 T-Bird LX 4.6L 2V, Stage 2 PI H/C/I on NPI block, Ported Manifolds, 2.5" Dual Exhaust, 10" converter, 3.73s, 93 tune on street tires.
14+ SECOND CARS
  1. 14.063 @ 097.84 - 08/2012 - John Speziale - T-Bird 3.8L SC
  2. 14.076 @ 100.14 - 11/2012 - Wolfer - 94 T-bird LX 4.6L, 2V/PI N/A
  3. 14.083 @ 101.90 - 05/2014 - miguel5671- 92 Tbird SC M90
  4. 14.205 @ 099.58 - 06/2017 - 4point6r0x0rz - 95 T-Bird LX 4.6L 2V '02 Explorer block, Trick Flow heads, Comp Cams custom grind, Circle-D convertor, 3.73 gears
  5. 14.245 @ 097.69 - 07/2012 - XR7 Phillip - 90 Cougar XR7
  6. 14.446 @ 096.81 - 06/2014 - XR7-4.6 - 94 Cougar PI headswap Marauder converter 3.55 gears
  7. 14.727 @ 096.55 - 09/2014 - NeedAbirdinVA - 91 T-Bird LX 4.6L 4V stock Mark VIII motor
  8. 15.442 @ 088.89 - 10/2012 - CometGSR - 95 Thunderbird LX 4.6L 2V NPI
  9. 16.515 @ 083.68 - 09/2012 - Allison Koesling 90 T-bird bone stock
Johnny Langton 12.16 @ 111.77 4.6 NPI N/A 2/2007
10.740 @ 126.83 Blown38 - 95 T Bird SC 2.0 AR 11/2010
Ah you snuck it in there on me. I think it was back in 2010 that it happened tho.
Got it. Thanks Chris.
It's showing 11/2011 on the MAMN12 DRT list. Are you sure it was 11/2010 ?
I think he needs to be moved back into 4th spot though LOL!!!! I believe it was 11/2010 at MIR!
Joker I believe was also 2010 April at the NVMC at MD. He didnt run much last year and I don't believe at all this year.
Add my crapbox to the list Ikea Monkey I mean trunk.
[email protected], 1.646-60', R429460, 95 XR-7, N/A V-8, 12-02-12
Got it. Thanks Steve.
Yea, Joker's been out of the loop for a while. I hope he can make it back to the track next year.
LOL Thanks. BTW, I like your subtitle. :tongue:
Gotcha Rick. Was that a new personal best or just a recent run?
Baddest N/A NPI in Canada
You can add me to the 12 second club.
1.706 60ft, 12.492 @ 109.563, August 2011
1996 Sport, 5.0L Big-Bore NPI 2V N/A
How much is it bored over?
To All: Please post your time and details in the following format.
11.062 @ 123.17 Blown38 - 95 T Bird SC AR 06/2012
Yup found the ticket 11-28-10. I thought it was in 09 originally. Everything runs together in my head.:confused:
Discussion Starter #14
LOL When you make as many runs as you do over the years I bet they do all run together.
Copy & paste owns you. :tongue:
Yup. :tongue:
CTRL C + CTRL V
No need to reinvent the wheel. I just took an existing wheel and will add a few more spokes.
Discussion Starter #17
somewhere in there belongs Hans and KDanner with their 12second N/A Tbirds. I just don't know the details.
I'll look around.
The hans that I'm thinking of ran an SVO - he was far from N/A.
I've got hanses slip in the car svo powered just to piss that monkey off I'll get it tomorrow, the monkey is really gonna be mad when Wayne's svo goes high 10s next year
Hans ran n/a also
12.69 or so
Discussion Starter #19
LOL Thanks for digging up Hanses time slip. (Not) :tongue:
You didn't tell me Wayne was cooking up an SVO monster! What's he up to?
I did notice that the green Tbird that he had sitting outside your garage for years was gone. I guess that's the car it's going into?
1 - 20 of 123 Posts
