1 - 1 of 1 Posts
Technical Administrator
Anti-Lock Braking System​
Below is an explanation of this system's operation:
Anti-lock Brake Systems (ABS)
Originally developed for aircraft, ABS basically works by limiting the pressure to any wheel which decelerates too rapidly. This allows maximum stopping force to be applied without brake lockup (skidding). If standard brakes are applied too hard, the wheels "lock" or skid, which prevents them from giving directional control. If directional control (steering) is lost, the vehicle skids in a straight line wherever it is going. ABS allows the driver to steer during hard braking, which allows you to control the car much better. In the old days, drivers had to know how to "pump" the brakes or sense the lockup and release foot pressure in order to prevent skidding. This meant that if only one wheel lost traction and started to skid, the driver would have to reduce braking force to prevent a skid. The advantage of ABS is that the brakes on the wheels with good traction can be used to the fullest possible amount, even if other wheels lose traction.
In operation, the wheelspeed sensors at each wheel send electronic pulse signals to the control unit. If wheel lockup (rapid deceleration) is detected during brake application, the computer signals the valve unit to limit the hydraulic pressure to the wheel cylinder. This is usually accomplished by diverting the fluid into a small reservoir. The fluid is later pumped out of the reservoir and returned to the main fluid reservoir when the brakes are not being applied.
The anti-lock brake system tests itself every time the vehicle is started and every time the brakes are applied. The system evaluates its own signals. If a defect is detected, the system then turns off, leaving normal braking unaffected.
1 - 1 of 1 Posts
