Is it me, or are the cross bolts for the main caps missing?
got a part number and source for those?
You might be able to get the "1-time use" bolts from Ford. Otherwise you can get re-useable bolts from MMR http://www.modularmustangracing.com/ P/N 400025C for $69.99
MMR TEKSID (93-98 Aluminum) Block Racing Sidebolt & Washer kit
Replace the factory 1 time use side Block bolts with this MMR re-usable high strength Allen Bolt, black oxide coated for corrosion protection and strength. Maintains cap alignment under the hardest of loads and HP. Recommended for 500+ HP applications.
I see its a reman. Do you know if its already been bored and to what size?
